2002 Perfect Pass Servo Wheel Problem
  • wakehead
    • Dec 2009
    • 240
    Hi All,
    My Servo wheel for my perfect pass does not seem to be working. It does not spin freely so basically right now it is as if it is seized. I tried to turn it slightly with vice grips and didnt want to put too much pressure to the point that I break something inside... does anyone have any ideas. I am not sure if I have to replace that cylinder loking unit under the knowb that turns and sets when the engine starts ... Right now the throttle still works as if i dont even have servo wheel because it is always stuck ion the same position.
    What are your suggestions.
    210 SANTE
  • wakehead
    • Dec 2009
    • 240
    I think that the piece is called the "Perfect Pass Servo Motor"
    210 SANTE
    • NigelC
      • 161
      • UK
      • 2010 Ski Nautique 200 Open Bow Team Edition
      Is it seized with the power off?? The knob should turn quite freely by hand when no power is applied. There is a large gold coloured resistor near the assembly, does that look OK, is it burnt??
      Sounds like you need a new servo motor assembly.
      2010 Ski Nautique 200 Team Edition Open Bow, Radar Strada
      Dealer: http://www.midlandsnautique.co.uk
      • wakehead
        • Dec 2009
        • 240
        The resistor is still mint on it .. looks perfect. the knob does not turn at all even when the engine is off. It has been like that since the winter I am imagining as I am up in canada. i have heard of a few cc fans taking them apart and oiling up the gears as they were rusted together.. Has anyone tried doing this ?
        210 SANTE
        • NigelC
          • 161
          • UK
          I haven't tried tearing one apart but it sounds like you have nothing to lose. I am sure the guys at PP could supply a new unit quite quickly. Their customer service is excellent.
          • bdow
            • Nov 2009
            • 14
            • Orlando Fla
            • 1984 2001 2003 SANTE
            I partially took mine apart… The motor freezes up from water/moisture, I fixed my frozen servo motor by filling it full of Corrosion X (which is a penetrating oil/anticorrosion spray), and letting it sit overnight. That was over a year ago and it is working like new.
            • hyparks
              • Feb 2011
              • 302
              • Brownhills, United Kingdom
              • 2001 Super Air 210
              There's no gears inside. It's basically a magnetic shaft.
              The servo motor is a step motor.
              As the power is applied to the motors windings around the outside of the shaft it pulls the magnetic shaft round.
              Mine was seized.
              I took it apart and cleaned the shaft up with some sand paper.
              I also used a sand paper flap wheel in the end of a battery drill and cleaned the bore of the motor with it.
              Now turns freely.
              Have a go yourself. It sounds like your motor is seized so its worth having a try anyway.
              Worst case scenario you have to get a new motor.
              Hope this helps
              Sent from my Desire HD using Tapatalk
              Current
              2001 SAN 210, GT40
              Previous
              1994 Mastercraft Pro Star 190
              • TRDon
                • Oct 2007
                • 722
                • MN
                I replaced mine when it did that. Had I known it could be taken appart, I would have tried it. The negative to turning it with force is I broke the knob and had to order a new one of those too. It was pretty cheap, it was all about 200 if I remember correctly.
                • grkero
                  • Dec 2010
                  • 65
                  • Northern California
                  • 2005 SAN
                  I replaced my 10 year old servo motor. It was frozen solid, couldn't even twist it. I was able to buy one from a local dealership, but PP can supply it as well. Very easy to swap out.
                  TRDon, I did the same thing with my knob. I actually picked up a knob at Radio Shack and tried to epoxy the string from the servo cable into the knob. Long story short, I had to re-epoxy the thing back into the knob twice on the water one day... huge pain in the *** (my fault).
                  2005 Super Air 210 (white/black) - EX330
                  1991 Barefoot Nautique (red/black) - 454 chevy w/ v-drive
