Carpet Replacement
  • GroovyNautique
    • Oct 2006
    • 77
    • Calgary, Alberta, Canada
    Carpet Replacement
    I've got all of my old carpet out. Now I'm trying to get the old glue out. Good times. Scraping it only gets me so far.
    Do i have to get every single bit of old glue off of the fiberglass or can I get away with some glue or should I pick up a giant jug of industrial goo remover and just get rid of it all?
    Thanks!
  • pzthk6
    • Mar 2008
    • 68
    • St Cloud, FL
    • 2014 SAN 210 2007 SANTE 220 1989 Centurion Barefoot Warrior Comp 1991 Concept 21' CC
    I would suggest using a large disc sander with 80 grit and just get as much as you can off. You might go through a few discs gumming up but it will prep the surface at the same time for the new glue and carpet.
    • GroovyNautique
      • Oct 2006
      • 77
      ok. thanks! that sounds like a much better plan than using a chemical strip. I was worried about tearing up the floor with a sander, etc, but should be ok.
