Hesitation/fuel delivery diagnosis...
  • tdc_worm
    • 532
    Symptom: sluggish acceleration under all conditions (including fulll throttle). Wide open throttle speed is normal
    Conditions: fuel did sit for 2 months over the winter w/o stablization. Have replaced run over 150 gals of fuel thru tank (from the same source I fuel my other vehicles). Have changed the FCC filter PN# 082026. My boat does not appear to have a primary fuel filter inline PN# 080024. In it's absence that leaves the low pressure rule pump, the high pressure fuel pump, the injectors as my problem. Possible the TPS? Thoughts?
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    What boat? Big difference between an 80s model and 2011! hehe.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • tdc_worm
      • 532
      Oooops.....
      2007 zr6
      • AirTool
        • 4049
        • Katy, Texas
        TPS should throw a code.
        • tdc_worm
          • 532
          Suppose that means a trip to the dealer to hook it up to a computer for diagnosis?
          • tdc_worm
            • 532
            • tdc_worm
              • 532
              Bump for any other expertise....
              • AirTool
                • 4049
                • Katy, Texas
                Can't you scroll through the warning codes on the dash? Check your manual to see if TPS would show up. Some of the code descriptions show on the dash pod.
