My 2007 SANTE with 300 hours has suddenly struggled to get out of the hole and on plane. It will only reach a max speed of 36mph. It struggles even more with a rider and the ballasts full. It would only reach 18mph when my son was riding, but at times it will surge to a slightly greater speed. The distributor cap had to be replaced just prior to this because the engine would not start and it had a hole in it. Both exhaust manifold gaskets were replaced and the spark plugs too. Still no solution. Any suggestions would be appreciated.
I had the same problem with a brand new pcm distributor cap and rotor. The cap started crossfiring after one week. The only way I could figure it out was with a timing light on each plug wire. The flashing pattern should be steady and consistent from cylinder to cylinder. Don't count out the wires either.2005 SV-211
