jabsco ballast pump running in reverse
  • Ribit5
    • Apr 2006
    • 27
    • Manitoba, Canada
    2007 - 211 team - great boat
    had a problem with ballst pump not working.
    no - problem, read about it, pulled out the pumps, checked impellers, 1 was spin out on the center, a second one marginal, third OK
    bought all new green replacement impellers.
    put it all back together, starboard pump works great.
    however both belly and port pumps seem to work in reverse to what should be on the dash.
    these 2 fill when switch in indicating emptying (flashing)
    and empty when solid on ....
    check voltages at connectors ... all 3 are the same
    took impeller out on 1 and reversed (didn't think it would make a difference ... and it didn't)
    strange ....
    it all works, but it would be nice to get back to filling when light is solid, and emptying when light is flashing
    checked the forums .... 1 similar problem with 0 responses.
    help ??
  • Chexi
    • Feb 2025
    • 2119
    • Austin
    • 2000 SAN
    Just reverse the connection of your wires or reverse the pump head. You probably put the pump head on in reverse when you changed the impellers.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • Ribit5
      • Apr 2006
      • 27
      • Manitoba, Canada
      pump head not removed, just the bottom access plate to replace the impellers. no changes to wiring
      • Chexi
        • Feb 2025
        • 2119
        • Austin
        • 2000 SAN
        Ok, then I cannot explain why things are working backwards... however, you can still fix them by either reversing the wiring or reversing the pump heads.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • Ribit5
          • Apr 2006
          • 27
          • Manitoba, Canada
          took the wiring connectors apart and reversed the wiring on the 2 pumps.
          all works as it should now.
          strange that the pumps are wired differently. I took a look at the position of the orange / black wires at each pump.
          If you have to replace a pump, it may not be a simple plug and play, the wires may need to be reversed.
          oh well ... all is back to normal ....
          surfs UP
