I have a 98 Super sport w GT40 and an rpm perfect pass, Occasionally I get a grinding noise when it is in neutral, it happens randomly & sporadically doesn't matter if I ran it for a couple hours or just started it up no real pattern, occasionally you can hear a light "rubbing" sound when its in gear & then it will be brutal grinding in neutral. If I turn the engine off I can immediately restart it & its fine no noise.
Any ideas? I called the people that serviced it last & they said it would need to happen more consistently before they would be able to track it down.
someone suggested possibly the started trying to engage,
I doen't believe its the transmission just had that serviced & fluids changed 40 hours ago (2 months ago), can't totally rule it out
any ideas
thanks
any ideas
thanks
