I've got a few questions on drilling some through hulls above and below the waterline for ballast on a super sport.
First the intakes below the waterline. I know the general idea - hole saw in reverse until you get through the gel. Establishing the exact place to drill is the nail biter as far as i can tell. I've heard of the use of magnets to locate the hole. In this case I'll be going on the opposite side of the raw water intake, beside the transmission. Would it not be OK to drill a 1/4" pilot hole from the inside of the boat? Then of course get underneath and finish with the hole saw? It seems more precise than lining up magnets.
When I am drilling above the waterline in the neighborhood of the bilge through hulls, there is a carpeted 'false wall' on the inside. Should I just drill through from the outside like its not even there? Or should I be somehow taking this down. Don't know if thats possible or necessary.
Lastly, I'll be starting out with 2 pumps, and I'll add the third down the road. So as far as intakes go, like i said previously, they will be beside the tranny opposite the raw water intake. I plan to have the 2 intakes for the rear bags there. When I add the third intake for the center locker, where is the best place for that one? Along with the other 2? I can't really go on the other side of the transmission where the raw water intake is. That intake has the hull formed for it, and there is some kind of plate running up to it, not leaving any room for anything. Would having 3 intakes in a row weaken the hull? Would that many cause draft issues?
Thanks for any input
