My 2002 sante seems to be taking in some water. I am not sure from where but bilge always seems to pumping water whien I am out on the water. Does anyone have any ideas or suggestions where I should start looking?
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Obvious places are shaft and rudder packing. If you do much surfing, check the hull to deck seal and make sure you're not tasking water in the side vents.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Probably a slim chance the same thing is happening to you, but I started taking water on from the exhaust muffler. It's that big fiberglass muffler that the exhaust hoses go into. It started out as a small hole that wore through the fiberglass that I patched up until the whole thing fell apart.2004 Super Air 210 (Current boat)
1999 Super Air 210 (Previous boat)
2003 Mastercraft X-2 205V (Previous boat)
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
That's a good point. Check to make sure there isn't any water leaking from the engine when it is running.
And yes, the packing is located at the point that the shaft comes through the hull. Same with the rudder.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I have an '04 that I think is leaking at the shaft packing, which I believe is a dripless packing. Despite being located directly below the v-drive transmission, I think I will be able to use a mirror to determine if it is in fact leaking. In the event it needs serviced, any suggestions on how to access it without removing the transmssion?
