Hot water under captians chair.
  • 555nova
    • Aug 2011
    • 12
    • Montana
    • 03 Air Nautique 216 LE
    I am Jason and my wife and I just bought our first boat, an 03 air Nautique 216 LE.
    We had the boat on the river the other night and I started noticing hot water puddleing up at my feet. I'm thinking it has to be from the heater, so I took apart the kick panel and the block off plate in the bow to check the hoses going to the heat exchanger. Everything looked fine lunder there. It looks like the water is coming from about 6" in front of the seat mount and not from under the dash area.
    Any thoughts on this would be very appreciated, thanks again Jason.
  • themaestro
    • Sep 2010
    • 36
    I had the same problem. Leak in the heater core. I bypassed the heater altogether, problem solved. Don't need heat in San Diego
    • 555nova
      • Aug 2011
      • 12
      • Montana
      What did you do to block off the heater?
      • swc5150
        • 2240
        • Eau Claire, WI
        • MasterCraft Prostar
        Disconnect the heater hoses from the motor. (If it's a factory install, and depending on the year, your hoses are likely red) Quick and easy, but you'll need to buy two plugs for the holes (any auto parts store will have them).
        '08 196LE (previous)
        '07 196LE (previous)
        2 - '06 196SE's (previous)
        • 555nova
          • Aug 2011
          • 12
          • Montana
          Thanks I just went out to work on the boat and a thunder storm had to roll in. Hopefully tomorrow I'll get a chance to look.
          • johnboyy7
            • Oct 2009
            • 409
            • houston
            one thing i did was i cut my hoses to the heater and installed metal water hose connections. i put the male and female ends so that i could bypass the heater but in winter i could easily reconnect. works good. i hope this will prolong the life of my heater core.
            btw. if you want to replace your heater core, there are several threads about which car it came out of. meaning you can pay 20 for one from autozone (i did) and make a couple of very minor modifications or pay 150ish for a new one.
            04 SANTE 210
            89 SPORT
            • themaestro
              • Sep 2010
              • 36
              I posted about this a few weeks back. This is what I did:
              "Temporarily, you can get a double-hose barb connector and connect the 2 hoses going in and out of the heater core. Be sure to hose clamp them. This way you can continue to use your boat until you get a replacement heater (if you decide to even replace it). It's a good idea to keep one of these double hose barbs on the boat in case this happens again."
              • 555nova
                • Aug 2011
                • 12
                • Montana
                I removed the heater hose from the water pump and intake manifold and replaced the barbed fittings with brass plugs, taking the boat out tonight after work so hopefully the problem is fixed. Thanks again Jason
                • ClemsonDave
                  • Oct 2004
                  • 659
                  • Glen Allen, VA
                  • Ski Nautique 200
                  I usually cut both hoses and install brass garden hose quick disconnects. Install each in opposite direction so when your not using the heater, you can connect the hoses coming from block together. It also is a great way to blow the water out of the heater core for winterization.
                  Promo Team member
                  1999 196
                  2010 200 Team 2010 200 Team
                  2011 200 Team 2011 200 Team
                  2012 200 Team - 2012 200 Team
                  2013 200 Team - 2013 200 Team
                  2014 200 Team - 2014 200 Team
                  2015 200 Team - on the way
