Hey guys.. I have a 2000 SAN I bought about a month ago.. Nothing on the right hand side keypad works. Bilge,nav lights, nothing! I'm more worried about the bilge pumps than anything.. But before I spend 500$ on a keypad I'm not 100% sure is the problem where can I check for 12v feeding it? I haven't seen the on/off/bilge switch in my boat.. The pumps are 500 gph fully automatic.. Thanks for any help!
The red and black wire is for power and the green and orange is where the signal goes true. Use a multimeter to measure both the He and She plug.
then you can se if you have power.
Generally these keypads have a tendency to break.
There are other treads in the forum regarding faults and trouble seeking with these keypads, search and you shall find.
Good Luck.Last edited by Mazza; 08-16-2011, 04:22 AM.
