GT40 Won't Crank
  • SANCasey
    • Jul 2006
    • 68
    • Austin, Texas
    GT40 Won't Crank
    My 2000 SAN with a GT40 died on the lake today and then would not crank over. The starter turns the engine over, but it does not fire up. From briefly listening to the motor, I believe this is a fuel related issue. Does anyone know the location of all the fuses/relays related to the fuel system (pumps)? I want to be able to check all the easy solutions quickly before moving up to checking fuel pressure etc.
    Thanks in advance.
    CW
    Lift the engine cover. Turn the key on.
    Do you hear fuel pumps run for about two seconds?
    If no, check the safety lanyard.
    If yes, and still no start, now it is time to check the fuel pressure.
    • slob02
      • Sep 2003
      • 333
      Fuses are on the back side of the motor. Had problems with my 97 in the past. Yep, check the laynard if you don't hear the pumps.........if not, go to the fuses!!!!
      2008 Super Air 210 Team
      2004 AIR 206 Team
      1997 Ski Nautique 196
      1993 Ski Nautique SNOB
      • Mazza
        • Jul 2009
        • 30
        Had the same problem with my 2000 SN with a GT40.
        it was the safety lanyard.
        i would start there, it is the easiest place to trouble shot first, and most likely place for the fault.
        • Chexi
          • Apr 2026
          • 2119
          • Austin
          • 2000 SAN
          Hopefully a disconnected lanyard. If not, then hopefully the fuse. I think Casey had his lanyard switch replaced relatively recently.
          Now
          2000 SAN
          Previously
          1999 Air Nautique
          1996 Tige Pre-2000
          • Chexi
            • Apr 2026
            • 2119
            • Austin
            • 2000 SAN
            Also, the fuel relay hangs off the bottom of the ecu. There are two identical relays. One for fuel, one for ecu. I think the fuel one has the yellow wire. Lots of info on this site about them. Search under danielc name.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
            • SANCasey
              • Jul 2006
              • 68
              • Austin, Texas
              I will check the safety lanyard, but it was replaced 2 or 3 yrs ago. I might get my little brother from Big Brothers Big Sisters to come help diagnoise boat issues tonight.
              • Reel2002
                • Aug 2011
                • 7
                • Sandy, or
                • 2003 Ski Nautique 206
                Sounds like the low pressure fuel pump. Very common on the gt-40. What were operating conditions before failure?
