2011 PCM 330 engine sputtering
  • Calgary210
    • Oct 2010
    • 45
    • Calgary
    • 2011 SANTE 210-Sold 2008 Malibu VLX - sold
    Just finished wakesurfering, drained the ballast tanks heading back to marina about 35 mph and then engine started to sputter. I throttled it back to idle then tried to throttle up it seemed like it wanted to take off then just sputtered again. Limped it back to marina and it idled fine in slip, revved it up no sputter ???. I just filled up with gas and there is no reports of anyone else with bad gas that day it has 27 hrs on it, oil is clean and up any help would be great .
  • tchap1
    • Sep 2008
    • 22
    • SC
    • 2007 236 TE ZR6
    Start with a new fuel filter
    2007 236 TE ZR6[/SIGPIC]
    • Calgary210
      • Oct 2010
      • 45
      • Calgary
      I figured it out I replaced the inline filter, it was totally plugged with the drilling particles from installing the fuel gauge on the tank. When I blew the filter out a lot of the drillings came out. It runs like a dream now smooth plus has way more torque out of the hole.
      • Trops
        • 2
        • Newcastle australia
        • 2011 210 team
        may i ask y did u have to install a new fuel gauge for in the first place?
        • AirTool
          • 4049
          • Katy, Texas
          Somewhere I read there was a design defect in all of them and the gauges didn't read right.
          • Calgary210
            • Oct 2010
            • 45
            • Calgary
            I did'nt replace the gauge just the inline filter, but now that you mentioned the defect in gauges i wondered why I was getting weird readings sometimes. Now i visual look at the gas tank before i take off just to make sure I have enough gas for the day.
