Hi everyone... 1st of many questions I'm sure. I just bought a 2000 Super Air with the factory ballast system (1st nautique), and I have been searching both online and in my engine compartment for the seacock valve. I have read that it's under the pylon area in the front part of the engine compartment, in the port rear part of the engine compartment, etc, etc.. I don't even know what it might look like. I see the intakes (2 of them) on the bottom of the boat and I know it has to be between those and the hard tanks. It's not rocket surgery... but I'm at a loss. Some idea of what it might look like or what color it might be or how big the lines are so I can follow them would be great.
Also, are there 2 lines and 2 valves, one for each tank? when I open the vents near the driver's seat, one tank will fill and the other won't. Don't know if I have pump issues, one open valve and one closed valve, or what. It should fill slowly when I open the vent regardless of the pump, right? One tank is, and one isn't...
