Low Voltage!
  • Mamanautique
    • Apr 2011
    • 5
    • San Angelo, Tx
    • 2003 Super Air Nautique 210
    Low Voltage!
    Something is sucking the batteries, voltage running at 10. 2003 Super Air, has anyone run into this before? I replaced both batteries, thinking they were just old (5yrs old), but voltage is still low. Instead of disconnecting everything and reconnecting one at a time, anyone have any ideas?
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Are you measuring voltage at the batteries or are you relying on the less than reliable gauge in the dash?
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • Mamanautique
      • Apr 2011
      • 5
      • San Angelo, Tx
      I was referring to the gage on the dash, but the sensor is beeping as well, and we had to coast back to the ramp because we didn't have any power, we had to load with ballasts full because didn't have the power to empty until we turned the engine off, and horn wouldn't honk etc.
      • Chexi
        • Apr 2025
        • 2119
        • Austin
        • 2000 SAN
        Have you had your alternator tested? Check the belt tension on it as well. You might not be getting any charging from your alternator. My next guess would be a short to ground somewhere, but I think the more likely culprit is a bad alternator or alternator belt slipping.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • Mamanautique
          • Apr 2011
          • 5
          • San Angelo, Tx
          OMG! I had a belt squeeking, the same day all this happened! I'll check the belt to the alternator. Hope it is this simple, thanks so much.
          • crobi2
            • Dec 2010
            • 337
            • Texas
            • 2000 Super Air Nautique
            Ha Ha, one time we pulling a rider and smelled barbeque (or the boat on fire) but it went away so we forgot about it. That evening as I bedded the boat down, I saw the alternator belt down in the bilge. We run two batteries also and would not have noticed it until the motor quit if I hadn't luckily seen the belt down in the bilge.
            Rob
            2000 SAN
            • SeanNaPiob
              • 11
              • Victorville
              • Current - 2004 Super Air Nautique, Team Edition
              Squeaking could be the belt loose, or, the bearings in the alternator could be going bad and causing drag on the belt which would result in crobi2's situation! Before you tighten the belt, loosen it completely and spin your alternator by hand to see if it spins freely.
              Current - 2004 SANSE
              Previous - 1990 Seaswirl Spyder Skier DD
