YEAH... Finally.. starts and goes runs perfect! ..Thanks for the great advice... You where right on!!.. it was the ground at the battery.. It looked fine and yet after closer inspection it was cracked(underside of clamp) and loose.. $8.00 new wire.. and months later all is perfect on my 2003 CC 206..the 5.7L PCM.. runs awesome
Additional info: After talking to PCM further they gave me an OEM part number for the Throttle Position sensor(which as it turned out I did not need). OEM # 17123852 at auto zone the part was a duralast part # TPS140 cost was $40.00 in stock, 2 year warranty, ok to return (after i tested mine and it was fine i returned). On the other hand.. at the local boat shop the same marine part number as given by PCM is #R020041.. cost $90.. was not in stock.. one week to get , with a no return policy, same part.
