Holley Carb Rebuild? for 86 454
  • 86barefootspecial454
    • Aug 2011
    • 2
    • ontario
    • 1986 barefoot speacal 2001 with 454
    Hey
    Got my first Nautique this year. Its an 86 barefoot special with a 454. Been having issue with idle and back fires when hot. What it does is stall out at idle after running perfect for 25-45 minutes. But will start right back up after. if i drop the hammer after a start up she some times back fires than takes off like there is no loss of power at all. I had a sort period of power loss last week when out with a pile of friends. turned out the second two barrels were not opening cause the diaphragm was not opening them. replaced the diaphragm and cleaned out the suction airway to it. Got power back but still have this stall back fire issue. I have replaced coil, points, condenser, plugs, wires, and all electrical that a mechanic friend told me to. I first thought that this issue was the carb he assured me it was electrical. So I now am sure it must be the carb is not set up right and or needs to be cleaned. I am going to pull it off the boat and pull it a part and clean it up. I have had a hard time finding a rebuild kit. My local Holley dealer couldn't look up the number off the choke housing. So i took some pictures he told me it was a 4160 and gave me a general kit for repair with seals. Anybody have any tips on what not to do wile rebuilding this carb? I have rebuild many carbs off all my two stroke motors and the 5 other boats i had till i finally could afford a ski Nautique.
    I have never rebuilt a big 4 barrel carb before.
    Does any one have the stock settings that they used for these 454s?
    thanks
    86 Bare Foot Special 454
  • TRBenj
    • 1681
    • NWCT
    You'll get more help over at CorrectCraftFan.com with a boat that age.
    If original, you should have a 650cfm Holley 4160. The LIST number on the choke horn will tell you which rebuild kit you need... call the Holley Tech Line directly for them to ID the kit.
    Potential carb issues aside, have you set the timing properly? I would make sure the ignition system was dialed in perfectly before troubleshooting the carb.
    1990 Ski Nautique
    NWCT
      • Aug 2011
      • 2
      • ontario
      Thanks for the reply. I am going to check the timing first then a buddy of mine has a timing light.
