Where would I be able to find the correct sending unit for the gas tank of an '82 Ski Nautique? I have a generic one in there now and it isn't exactly close to being accurate.
RE: 1982 Nautique sending unit ?
The sending unit is a standard 33 ohm to 240 ohm rated unit make shure it is adjusted for your depth tank whick should be approx. 10". I have used tempo senders for a 12" and moved the float to adjust for the depth.
We have a 1982 SN model 2001. Consider the reading on the fuel gauge a rough estimate only. I'd call it +/- 3-4 gallons at any given point. I've filled until it overflowed and found the needle went shy of the "full" mark. I've also seen the needle suddenly jump from 1/2 tank to 1/4 tank.
I simply regard it as an imprecise estimate of remaining fuel.
