I fried a water pump impeller. After replacing it, I still cant get it to prime. I know it is installed correctly. This is a new water pump as part of the recall (for 02-03 excal330s) I got last year. I didnt have a problem until now. This pump came to me and it just had the o-ring seal for the cover and no paper gasket. I did a search and found several threads where it said for the Excals of all years to use the paper gasket and discard the o-ring. This is the first I had hear of this and acutally a suprise considering it came from PCM that way and I got only about 30 hours out of it before it killed an impeller.
What are the chances I got sent another non-priming water pump that my boat was originally recalled for? I dont have a gasket for it, should one come in a new impeller kit? I saw to use RTV or it will leak, still the consensus?
I really just want to get the boat back in the water so I really need some help on this one. I have gone far too long without wakeboarding this year and am really getting bummed out because of it
I have tried to email and contact PCM with no help as of yet and it has been nearly a week.
