Rudder leak on 2003 SANTE
  • Erik03
    • Sep 2011
    • 9
    • Chico, CA
    • 2003 super air nautique limited addition
    I have a leak on my 03' SANTE coming from the rudder assembly. Has anyone had luck tighting the packing nut a little? Or, should I be preparred to disassemble and reseal the whole thing? Thanks.
    Erik
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    It's not that hard to repack the rudder assembly once you get to it.After 8 years I would think you should repack it unless it has been done earlier. You can try tightening it a 1/4 turn but that will only delay the repacking bu a year or two at the most.There was a thread on here earlier that talked about adding a grease fitting to the nut. You might want to search that. Good luck.
    Nautiqueless in San Diego
    • Erik03
      • Sep 2011
      • 9
      • Chico, CA
      Thanks Rick, that's what I figured.
