ball park on service cost
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    what do you estimate this to cost me at a dealer? i already have everything but the steering cable and throttle cable. just no time to get it done.
    1. engine alignment
    2. replace spark plugs
    3. replace plug wires
    4. replace fcc filter
    5. replace steering cable
    6. replace throttle cable
    7. flush cooling system
    8. clean sea water section
    9. inspect risers and gaskets
    10.change transmission fluid
    11. change v-drive fluid
    12. water test
    13. winterize
  • migs
    • Aug 2008
    • 703
    • San Mateo, CA
    • SAN 210 TE
    my guess 2K
    Migs
    G21 - En route
    SAN 210 TE (Finally)
    06 Sky Supreme V220(previous)
    05 Sanger V210(previous)
    01 MC X1(previous)
    99 Air Warrior(previous)
    • gride
      • Jun 2007
      • 1441
      • War Eagle
      • 05' 210 team
      I was thinking between 2-3k. I'm guessing the steering and alignment are most expensive? I'm going to get a sealed coastal edition cable if I can
      • xlair
        • 694
        • Wisconsin
        Looks like about $1000 in labor (10 hrs @ $100/hr) + parts
        2001 Pro Air Nautique
        • teamseal
          • Dec 2006
          • 382
          • Panama city, Florida.
          • 2009 196 ZR-6
          1. engine alignment
          12. water test
          13. winterize
          With parts and labor in my shop you would be looking at about $1.500.00 pluss or minus a couple hundred dollars, provided you had the steering cable. We are at $85.00 per hour and 10 hours is a good estimate. A good shop can multitask, drain fluids while changing other componets. especially on a V-Drive where you have to get down in a compartment a tech should be able to do multiable tasks and piggyback functions. You would also get a complete Diacom printout as we would also run a diagnostic scan. Method to the madness!!!
          • AirTool
            • Sep 2007
            • 4049
            • Katy, Texas
            But will they actually give a credit for this? The auto mechanics I know won't.
            About the closest I've gotten is no labor to replace a belt they had to take off anyway. Also got free labor to install a sealed wheel bearing on my 4x4 becuase it was off already to do the ball joints. (Probably the owner felt bad because he then figured out my ball joints were good and the wheel bearing was the problem.
            In both cases, I paid list for the parts so they made $$ there anyway.
            • gride
              • Jun 2007
              • 1441
              • War Eagle
              • 05' 210 team
              When I had my mc liquid sports would always do each thing, mark it, and move on. Drove me crazy. I'll do the trans and v drive myself to save $. Thanks for the labor estimate. I'm also going to remove the compartment separators and as much as I can to make it easier on them. No life jackets or sacs left in or anything.
              • chief351
                • Aug 2007
                • 107
                • Ontario
                • 2015 SN200 ZR409
                Would anyone from Canada care to give an estimate for the above service? Maybe someone in the Muskokas who uses Pride marina :-)
                I'm 4 hrs from Silver Spray in Michigan so I would probably go there.
                Similar to many people on planetnautique I perform my own maintenance, but at some point I may need dealer assistance. Just curious.
                Thanks
                New ride 2005 SN 196
                Sold 2010-09-05 - 1990 SN - 610 hrs
                • Mark2
                  • Nov 2010
                  • 38
                  • Toronto Canada
                  • 2008 SV211 Team
                  I would not recommend Pride in Muskoka or any of their other locations for that matter. Complete rip-off and I really have to question whether their techs know what they are doing. I will give you an example, I had a bad starter this year. Pride charged me $700 to fix it which included a rebuild of the starter (which they told me cost $125 to a local guy), so therefore $575 labour to replace the starter. Completely ridiculous
