Question for those of you out there with the 502 and a heater. Mine blows lukewarm air no matter if a idle or at speed. I know I can put in the y fitting inline on the engine cooling pickup hose to help flow at idle but I don't think that's my problem since it's the same at speed. The supply line is tapped in on the bottom right side of the block and the return is plumbed into the water pump. Seems to me the supply should be comming off the top of the intake somewhere for the hottest water after it's gone through the heads. that's where I've seen the ones on the small blocks...
Anyone else out there had this problem???
Thanks Brian
Thanks Brian
