I'm having problems with my 1998 cb Ski Nautique not wanting to restart after it has been run for a while. The thing runs like a champ until you turn it off, then I have to Give it full throttle to get it running enough to limp home. After it cools down a while (20 min) it runs like a champ again. I have checked that the fresh air hose is still plugged in. Some one mentioned that was a problem. I also heard mentioned that the MAP sensor might be the issue? I have checked the kill swith and that is fastened well. I also have changed the fuel filter. Has anyone had a simular problem that can pinpoint this issue.
Do this.
http://www.planetnautique.com/vb3/sh...=Fuel+Pressure
The Gt-40 engine does not have any feedback into the engine's computer on what the air to fuel ratio actually is. It just has tables on how long it should leave the injectors open, depending on the input from various sensors. The computer assumes the fuel pressure is correct, and opens the injectors for the programmed time, depending on sensor input.
If you are having driveability issues with a GT-40 engine. you must check the fuel pressure, when the problems are happening.
