Had the boat out yesterday and it ran fine at skiing speeds. However, when we were looking for good water my buddy was running it at WOT throttle and it would drop down to 2,500- 2,700 RPM at full throttle, run rough and have some mis-fires. Once we stopped, waited and started again it would perform fine until we got it back to WOT then the same thing would happen. I just replaced the FCC filter, and I am thinking this is a fuel pump related issue. Any thoughts? Would it be the low pressure or the high pressure pump?
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
Does the red light come on? How's the temperature when you're running the engine that fast? Sounds like you might be going into Limp Mode.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Fuel pump would be my guess.
