2002 SAN GT40 Winterization -- Drain Plug Locations
  • jmo
    • Mar 2006
    • 707
    • MA
    #46
    Originally posted by goldfisch View Post
    My next ? Is if I circulate antifreeze threw the system will it run threw the v drive to?
    Yes - that will get it in there.
    2018 Ski Nautique 200 TE, H6
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      #47
      Hey guys when I pulled both plugs on my v drive shown in pic on page 1 nothing came out. should I worry about this. Or cycle antifreeze threw I want to finish tonight. thanks
      If there is water in the cooling hoses to the vdrive and you pulled vdrive drain plugs and no water came out then your drain plugs are corroded and clogged up. I had to punch through the drain port with a small screw driver to get mine to drain then later ended up sending it off for a full rebuild for other reasons.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        #48
        Originally posted by ejnautique View Post
        I would appreciate any diagrams/pictures showing the drain plug location for a 2002 SAN GT40. I'm planning on winterizing this weekend, last year I used the suck up antifreeze from a bucket method. Based on reading some posts, it sounds like I should also have emptied all the drain plugs before doing this.
        The marina that does my winterizations has been using the bucket method on my boat for 13 years. I know they're not pulling drain plugs. Why would you need to pull the drain plugs if the water jacket is already full of antifreeze?
        -Charles
        • jmo
          • Mar 2006
          • 707
          • MA
          #49
          You want to drain the water before pulling AF into the system so you don't dilute the AF and compromise the freeze protection.
          So pull the plugs to drain, put them back and then pull AF out of the bucket until you see it coming out the exhaust.
          ______________________________________
          2006 SN 196 Limited Excalibur
          2001 Super Sport Limited GT40
