2002 SAN Team Edition Winterization
  • Matt1422
    • Sep 2011
    • 5
    • Illinois
    • 2002 Super Air Nautique Team Edition
    I have been reading all of these threads on winterizing and I am still struggling. This summer i bought a 2002 SAN Team Edition, so now I want to make sure that I winterize both the ballast tanks and the engine properly.
    I have been looking online for a step-by-step procedure for both in a Manual or something but can't really find anything.
    So your input would be greatly appreciated.
    thanks
  • shonuff
    • Sep 2010
    • 157
    • Atlanta, GA
    • '05 SANTE
    http://www.planetnautique.com/vb3/co...res-GM-Engines
    The only thing missing from that guide is your v-drive. It's straight forward, 2 plugs labeled "water drain" or something along those lines.
    2005 SANTE
    • SoldTheBayliner
      • Aug 2011
      • 170
      • Northern California
      • 2000 Super Air Nautique
      I'm in the same boat, so to speak... 1st winter dealing with my 2000 SAN. for the ballast tanks, I pulled the line at the Y (where the main line splits to go to the 2 tanks, after the pumps. That is the lowest point in the system I think. It's right in front of the bilge pump in my boat. Do that and open the vents, and that should drain the whole system except maybe the pumps themselves. I pulled the pumps because they weren't working, but you could just blow into the line with a compressor and shoot everything that's in the pumps out of the thru-hull once you pull that one line.
