Hi all.
When I brought my boat the previous owner had removed the heater as it was frost damaged.
I have since purchased a new heater box and core and now want to install it.
The original heater water pipes are connected to the starboard engine drain point and the connection by the thermostat housing where one of the temperature senders are located.
Unfortunately I cannot use these pipes as they now feed hot water to the lpg system. ( I live in the UK so lpg is the best option )
My question is where can I now connect my heater pipes?
Can I do the same as the original pipes except connect one pipe to the port engine drain and the other pipe to the same place by the thermostat housing?
Sent from my Desire HD using Tapatalk
