Went out today and the boat ran great for the first 4 passes through the course.  On the 5th pass, when I gave it gas, it missed a few times and then stalled.  It would idle, but any time I gave it gas it would surge and stall.  Picked up some dry gas on the way home and ran it in my driveway for at lest 15 to 20 minutes thinking that was enough to pull through any bad gas.  When I increased to 1500 rpm or so, it would just surge and die.
The boat has 400 hours, Perfect Pass, and I replaced the low speed fuelt pump 2 summers ago, probably not needed, as I eventually traced the problem to the fuel pump relay. New filter put on at that time.
Temp was solid at 160 degrees, no red warning lights or anything come on. It sounds like it is running out of gas, yet it smells like it is running very rich.
Anyone have any thoughts on this?
Thanks
Thanks
