R/v anti freeze
  • i_am_am
    • Mar 2007
    • 43
    • randleman,nc
    • 1978 Correct Craft American Skier- 1st boat owned for 25 yrs Now have a 1999 Super Air that was bought trashed. Rebuilt the engine, steering, ballast, just anything exposed to salt water was replaced.
    #46
    Living in NC, the winter's are'nt as harsh as some of the MN and northern areas. I keep my 99 SAN hanging in the boathouse at the lake. If I look at all the HUNDREDS of boats hanging up around the lake, and if everybody winterizes with green AF, that's alot of toxics for the fish. I decided to use Starbrite's AF. I have used pink rv, low-tox, and green. I want to protect my lake. Here's a link.
    http://starbrite.com/productdetail.c...G%20Antifreeze
    Reading the fine print on af non-automotive af's is scary. Almost decieving when you see big letters -100 deg. One of the good things listed on the Starbrite is that it is designed for engines. It has corrosion protection also. I just want to find some local so I don't have to order it.
    78 CC Amer skier(25yrs)
    >>99 SAN gt40<<
    • gtxragtop
      • Oct 2011
      • 56
      • Worcester
      #47
      Do I need to put antifreeze into the raw-water/seawater section of the cooling system after draining?
      MerCruiser requires the use of propylene glycol antifreeze (with a rust inhibitor for marine engines) in the seawater section of the cooling system. Damage caused by freezing or improper winterization is not covered by the limited factory warranty.
      Back to Top
      Can I use propylene glycol (RV antifreeze) in my engine?
      Propylene glycol antifreeze with a rust inhibitor is approved for use in the raw water cooling system for cold weather storage purposes ONLY. However, if your engine is equipped with a closed cooling system, you should always use a 50/50 mixture of ethylene glycol antifreeze and water in this system. Even if you don't live in a freezing climate, you should still use an antifreeze/water mixture rather than plain water. Antifreeze mixtures have superior anti-corrosion and boil over protection properties.
      • gtxragtop
        • Oct 2011
        • 56
        • Worcester
        #48
        Originally posted by DanielC View Post
        The pink antifreeze is NOT ethylene glycol.
        Ethylene glycol is the green "Prestone" auto antifreeze.
        Correct. It is Propylene Glycol. See http://www.homedepot.com/catalog/pdf...df5e792462.pdf
        • gride
          • Jun 2007
          • 1441
          • War Eagle
          • 05' 210 team
          #49
          Use pink dex 50/50 in my closed cooling system. Green can get jellylike.
