Heater Install ??'s in 95' SS
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    I'm installing a Heatercraft in my SS which has a GT40 engine. Can someone post a picture of the exact places on where to attach the hoses to the engine. Also, to install my defroster vent is it ok to drill from under the dash upward towards the window if I put a lot of tape down on the gelcoat? or must I remove the windshield and drill down to do the vent? If I have to remove the window, how hard is that?
    Thanks.
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
  • bradb
    • Sep 2003
    • 94
    • Parksville, BC, Canada
    RE: Heater Install ??
    wake_fun,
    When I put the defrost vent in my 94 ski this winter, I just drilled up from the bottom, but put some tape over like you mentioned, and drilled VERY slowly... It turned out fine, but I might have just been lucky... Like I said, go slow and you will probably be fine.
    B
    • skinautique
      • 1749
      • Colorado
      I would definately pull the side of the windshield off. Not too hard to do and you don't have to worry about the drill hitting the windshield. I don't have a picture but you need a hose connected to the temp sensor and one installed on the "u" elbow of block plug on the starboard side.
      • nms1991
        • 477
        Use the block plug in the side on the starboard side instead of the elbow plug it flows bettter. I recommend removing the windshield to drill the defroster vent. Don't forget to chamfer the screw holes to prevent stress cracks in the gelcoat, you can use a phillips bit in your drill to acomplish this.
        • sperbet
          • Aug 2004
          • 283
          • Truckee, CA
          I can get you some photos of my 95 in a few days. It's snowing right now so the boat is inaccessable
          Ummm, I\'ll take the REAL 210 please. Thanks.
          • ag4ever
            • 1180
            I posted my installation of a heater on an '02 SAN a while back. Mine has the chevy motor, so there are some differences, but it should be similar.
            Here is the link to my install:
            http://www.planetnautique.com/index....271&highlight=
            • wake_fun
              • 1330
              • CA
              • 1995 Super Sport
              Re: RE: Heater Install ??
              I pulled the front windshield off, so I'm going that route for the defroster. I haven't looked at where to attach the hoses yet.............kids and work=not that much spare time, but I will get to it.
              Photo Album
              Ballast Install 1
              Ballast Install 2
              Amp Install
              PPass Install
              Alternator Install
              • wake_fun
                • 1330
                • CA
                • 1995 Super Sport
                That would be great!!!!!! :grin:
                Photo Album
                Ballast Install 1
                Ballast Install 2
                Amp Install
                PPass Install
                Alternator Install
                • sperbet
                  • Aug 2004
                  • 283
                  • Truckee, CA
                  wake_fun, did you happen to get my PM about that mainfold you made for your ballst system??
                  • wake_fun
                    • 1330
                    • CA
                    • 1995 Super Sport
                    Just checked and got it........check yours now :grin:
                    Photo Album
                    Ballast Install 1
                    Ballast Install 2
                    Amp Install
                    PPass Install
                    Alternator Install
                    • bcrandall
                      • Sep 2004
                      • 70
                      • Oklahoma City, OK
                      This is unrelated to your heater question, but I just got my 95 super sport and would like to hear your 2 cents worth regarding tower selections. Why did you choose the Titan?
                      • wake_fun
                        • 1330
                        • CA
                        • 1995 Super Sport
                        I bought my boat used and it was already on it, so that's how I ended up with that tower. But I can tell you honestly, this tower is so amazingly solid!!! It doesn't move, doesn't sway, and makes no noise whatsoever.
                        The only thing is that on my boat I have to take off the front wishbone to get it under my garage header. You might be able to get away from that by mounting the tower a little bit further forward than what mine is. It only takes me about 3 minutes to take it off, so it's no big deal to me.
                        Photo Album
                        Ballast Install 1
                        Ballast Install 2
                        Amp Install
                        PPass Install
                        Alternator Install
