Was changing pre filter & fuel filter on my sv211 had disconnected fuel tank as swapped over packing gland easier to get at shaft with fuel tank out.We then are not sure which hose went to the fuel pre filter & which to the FCC one is marked in red on tank & the other is connected to centre point on tank.I believe one is return line to FCC & & other inlet to pre fuel but not sure if it matters at tank
Thanks so much for any help
Mark
Mark
