EXcal 330 oil amount
  • TRDon
    • Oct 2007
    • 722
    • MN
    I just winterized my boat yesterday. I looked it up in the maintenence manual and it said it takes 4 qts with filter. After filling it up and letting it run with 4 qts, it registered a qt low. Does it really take 5 qts? It seems to make more sense to have 5 in there seeing as my other boats were 4.5-5, and this one is newer. I dumped another 1/2 qt in there and let it sit overnight to get all to the pan and let it drain back from the motor. I figured that is the only way to really test it. Is the book misleading?
  • firefighter
    • Oct 2009
    • 63
    • Winter Garden, fla
    • 2013 ski 200 O/B Team 2012 ski 200 O/Bteam sold 2011 ski 200 O/B team sold 2010 ski 200 O/B team sold 2009 ski 196 2008 ski 196 2007 ski 196 2006 ski 196 2005 ski 196 2004 ski 196 2003 ski 196 2002 ski 196 2001 ski 196 2000 ski 196 1990- 1999 ski 196
    The motor seem to like 4 and 1/2 qt's You should be fine. That is what I run in mine
    • core-rider
      • 1375
      • Huntsville, AL
      • 2003 Black SANTE
      4 qts plus 1 qt for the filter. Usually 4.5 will do the job as I can never seem to get all 5 out.
      Jason
      All black 2003 SANTE
      -- Southern Fried --
      • AirTool
        • 4049
        • Katy, Texas
        4.5 if changed properly.
        3.5 if changed in a hurry.
        I've never put 5.0
        I drain into an old oil container....and usually put in what i get out. Or if I get at least 4, I'll pour in the entire gallon jug then start topping off in the water using a one quart bottle. Usually takes half then I have half a bottle to carry in the tow vehicle to top off between changes....but it generally needs very little and I end up pouring it in the tow vehicle.
        • TRDon
          • Oct 2007
          • 722
          • MN
          Thats good to know, the book said 4 with a filter. I have about 4.3 in there and it is reading at max level.
