stream from prop seal
  • viperjuice
    • Oct 2011
    • 20
    • Mass
    • 2008 Sv211
    Purchased my first boat this year, a 2008 sv211. Was running the boat in the driveway before I drain the oil while winterizing and noticed that the is a good stream of water coming from the prop seal. I figured that it's suppose to leak since it's got a hose going to it. Question is, how much do they usually leak? Is a stream too much?
  • core-rider
    • 1350
    • Huntsville, AL
    • 2003 Black SANTE
    That is the dripless packing gland. You should have a decent stream, probably 3/16" - 1/4" in diameter. That water is what helps cool and lubricate the shaft seal instead of it dripping inside the hull like a normal packing gland would. Yours sounds normal. Rock on!
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • viperjuice
      • Oct 2011
      • 20
      • Mass
      • 2008 Sv211
      awesome.. happy to hear that.. thanks
