Analogue speedometer
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    Hi everyone.
    My analogue speedo does not work. I have the jumper cable from perfect pass unit connected but get no speed reading on the gauge.
    Perfect pass display reads fine.
    Is there any way I can test the gauge to check whether the problem is the gauge or the cable etc?
    Thanks in advance.
    Sent from my Desire HD using Tapatalk
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
  • hyparks
    • Feb 2011
    • 302
    No one ever tested one?
    Current
    2001 SAN 210, GT40
    Previous
    • hyparks
      • Feb 2011
      • 302
      Ok. I pulled the gauge from the console today to try and repair. Got to be replaced anyway so if I can fix it then great.
      I connected the gauge to a 12 v battery and tried linking accros from earth to the signal post. Needle didn't move.
      So I tried the opposite accross the 12v to the signal post. Again needle didn't move.
      So gauge definitely no good so I decided to take it apart.
      Eventually managed to get the front off the gauge and when I tried to move the needle by hand it was quite stiff.
      Worked it backward and forward a few times then reconnected it to the battery.
      Now when you connect the +12v to the signal post the needle spins round.
      Yet to test on the boat but hopefully for half hours work it's now sorted.
      Current
      2001 SAN 210, GT40
      Previous
