Hey guys,
So when I pulled my battery on my new to me 2006 196 I discovered that the negative battery clamp was broken. I was able to pull it off without loosening it, which concerns me, though it hasn't been a problem this Fall since I got it (I knew I should have inspected the battery before driving off with it). Since I have to replace it, does it make sense to switch to ring style connectors? The ring connectors appear like it would be far more secure and easier to fasten and remove each Spring and Fall?
My interstate battery (original) only have the SAE terminals, but I figured its time for a new battery anyways given its 5 years old so I will get one with both connectors.
Thanks,
JMO
Thanks,
JMO
