Hey guys.
Having some difficulty changing out the oil in my V drive and son't want to have the same issue with the tranny.
I have the Walter V drive / PCM trans combo in my 2003 SAN
I have a vacuum pump setup that worked perfectly for the engine oil, but I've only been able to get around 200ml or so from the V Drive.
I don't have a good seal against the dipstick tube and is is sucking air. Is this my issue.?
I'm also not at the bottom of the housing by using the dip stick tube.
I have done a bit of a search, but didn't turn anything up about this issue.
Any ideas.?
Any ideas.?
