Oil around spark plug
  • jedgell
    • 170
    • Bozeman, MT
    • 2004 SN 196
    I recently changed out my spark plugs and found a little oil around the thread and neck area on one of the plugs. Is this a concern? The boat runs great and only has 250 hrs, (GT-40). The plug was tight, and there's no oil on the outside of the engine.
    Also, the plugs had a little rust on the threads. Do I need to worry about that? I just read on another thread that you should put anti-sieze on the threads before installing, I guess that would prevent the rust?
    Thanks for the feedback.
    \'95 SN Signature Ed.
    GT-40
    PP Stargaze
    **For Sale**
  • Nates78Ski
    • Jan 2005
    • 323
    • Rossford, Ohio
    RE: Oil around spark plug
    Be carefull using anti-seize on plug threads. The anti-sieze will effect heat transfer from the plug and any anti-sieze on the ceramic of the plug can cause arcing & misfire problems.
    My \'78 SN
    • wakejunky
      • 679
      • Ca
      • 2003 SAN
      Don't know the reason behind this but, when I was servicing CC boats, all GT40 motors had this same problem. Nothing to be concerned with.
      Although, there might be a mechanic here who can attest.
      Chris
      • M3Fan
        • 1034
        Could be a small leak in the valve cover above the spark plug. See if you can trace it upwards.
        2000 Ski Nautique GT-40
        2016 SN 200 H5
        www.Fifteenoff.com
