Upgrading my ballast pumps..sounds like maybe tanks as well??
  • youngunz
    • Mar 2011
    • 150
    • Barrie, ON
    • 2002 SAN
    Just a quick question for those who have upgraded there ballast system..As I look to purchase & install 3 Jabsco ballast puppies, I believe the current ballast situation in my '02 SAN may not be as striaght forward as swapping out one pump for another.. In fact, it appears as though I will also have to get rid of the plastic holding tanks in the back because I will now be running of only one pump to fill/empty (per tank)?
    Currently my boat has two aerator pumps at the top and base of the tank, which made me think I may have to buy bags as well..Not a bad thing!!
    Any thoughts or suggestions would be much appreciated.
    Now
    2002 SANTE
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    Are you thinking of running these off the keypad?
    You should checkout this thread about the process of me doing this on an 03 - http://www.planetnautique.com/vb3/sh...-SAN-touch-pad
    Good luck!
