Help where do these wires go?
  • hyparks
    • Feb 2011
    • 302
    • Brownhills, United Kingdom
    • 2001 Super Air 210
    Hi again everyone.
    I did something a bit foolish really. Whilst doing some rewiring on my dash pod I removed some wires from the back of the gushes.
    One is the link from the perfect pass paddle wheel to my speedometer. The photo with the green and white wire. I believe they are signal and ground but which is which?
    Also the photo with the red, black and white wires. These come from the small knob underneath the dash. I think this alters the needle position on the speedometer. But again which wire is which?
    Finally the last photo has a grey wire with a connector on the end that was never connected to anything. The one I am pointing too. There is also a black wire which connects to the rev counter. Both these wires go into the black sheath you can see on the left of the photo. This then goes to the rpm connection on the perfect pass module. Like I said this grey wire was not connected and can see no where it should connect to. Just wondered if it should be?
    Thanks guys.
    James
    Sent from my HTC Desire HD A9191 using Tapatalk
    Current
    2001 SAN 210, GT40
    Previous
    1994 Mastercraft Pro Star 190
  • hyparks
    • Feb 2011
    • 302
    Gushes meant to be gauges. Lol. Next time I take wires off il note down where I took them from .
    Current
    2001 SAN 210, GT40
    Previous
    • Bri93SN
      • Jan 2012
      • 29
      • Boston
      • 1993 Ski Nautique Standard
      I know on the older boats, the grey wire typically is the tachometer signal. You may have to see if you can get at a Perfect Pass Manual, there's a couple version up on CorrectCraft Fan. Or, you could go onto Perfect Pass's web site and see what you can find.
      Both PP website and CorrectCraftFan have PP Installation videos. The latter up on Youtube. You may see where they go with certain wires.
      • hyparks
        • Feb 2011
        • 302
        Thanks will check it out.
        Current
        2001 SAN 210, GT40
        Previous
        • vanislwake
          • Apr 2010
          • 113
          • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
          I think this might help you out!
          http://www.planetnautique.com/vb3/sh...-Gauge-Install
          Current '02 sante full '06 updated
          Previously owned:
          07 San 210
          05 Sante
          03 Sante
          01 San 210
          02 Air nautique
          00 Air nautique
          + another 15 non nautiques
          • hyparks
            • Feb 2011
            • 302
            Excellent. Thankyou.
            Current
            2001 SAN 210, GT40
            Previous
