I replaced the skin on my engine hatch last winter. I got the stapler from Harbor Freight and staples from Amazon.
A heat gun definitely helps stretch it. Also pick up some plastic painters drop cloth from Home Depot. That goes between the skin and the foam cushion. It helps you slide the skin around to position it just right. You'll also need plenty of masking tape to tape the ends down while you're stretching.
Good luck. I got my skin from nautiqueskins, I heard copycat skins didn't always fit right so I'm betting its not as easy as you're thinking.
