I'm thinking about adding a second battery, if I find the space. I don't really trust a jump box. My dilemma is what is the best method. I came up with this and wanted to see if anyone had any thoughts. Basically I would keep my current dual battery switch and just run the Surepower 1315 isolator between the two batteries. It would give me the ability to use either battery for all power. Typically, I would use the starter battery while running the engine for all accessories. In coves, I would switch to the Dual Purpose battery. Also, I could switch to the Dual purpose for the bilge overnight (vacations). What do you think?
I like the Blue Sea VSR, but I just realized I'm going to have to put one battery about 15-17' away from the other. If I used my initial setup or the Blue Sea, I would have a 34' run from the House battery under the front to seat the Amp distribution block. Basically it would run all the way around the boat. I can just make a run from the House battery directly to the distribution block (about 4-5ft). This is probably what I'm going to do:
Previous:
2011 Super Air Nautique 210
1994 Sport Nautique
Second Battery
I just installed the blue sea and installed an optima under the dashboard. Lots of wire but it works great. 93 sport.1993 Sport Nautique
- New Interior - Copycat Covers
- Ramlin Trailer overhaul
- Buff and polish oxidated gel coat
- Exhaust repair
- Holley rebuild
Previous: 1980 Mastercraft - Lake Lanier. GA
