ACME 1234 prop/ballast upgrade
  • ditchdoc7
    • Aug 2011
    • 19
    • Georgia
    • 2007 SUPER AIR NAUTIQUE TE
    Greetings CC owners...
    I am in the process of upgrading my 220's ballast system. My current prop is the 644 and in doing some reading on the forum, it seems that my next step is to get the ACME 1234.
    Does anyone have any suggest on the best place to purchase one? I am guessing thats its going to run between 500-600.00??
    Thanks
    DD7
    Wake-up and Ride
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    Is your prop a left hand or right hand? You mentioned 644 which is right hand. I mention it because I thought the 220 would have a left hand prop (645).
    There is a prop selection guide online at wake props.com with recommendations based on the total amount of ballast https://www.wakeprops.com/wakeboard-...oat-propellers
    • bchesley
      • Feb 2006
      • 1252
      • Tyler, Texas
      06 220's had Rh props. In 06 the only boat with a LH was the 210. In 07 they all went LH.
      2001 Super Air Nautique
      Python Powered
      100 Amp Alternator
      Dual Batteries
      Many upgrades coming...
      • thedude
        • Apr 2007
        • 451
        • SW PA
        Use the planet nautique discount code (DP9PNA) and order from Delta Propeller Co. I just ordered a brand new ACME 1464 it was something like $420 shipped with the PN discount. I'm thinking you will either want the ACME 1236 or 1464, they seem to be the most popular props for the 210's, but I can't speak for the 220's.
        • ditchdoc7
          • Aug 2011
          • 19
          • Georgia
          Thanks!!! I did confirm that the prop that I had was the 644 RH and ordered the ACME 1234 from Delta.....
          Wake-up and Ride
