How many plugs are there, and where are they located? Anyone have pics?
Please don't take this the wrong way, but if you aren't sure by looking at the motor, you might want to have a mechanic do the work. It's surprisingly easy to mess up plugs if you're not familiar with replacing them.
In any event, there are 8 and you can find them by following the plug wires.Previous boats:
2015 G23
2008 SAN 210
2002 XStar
1995 Sport Nautique
Question is too vague, LOL.
If you are referring to plugs to drain the water there are several in various places, if you have a hot/cold water shower would be an important detail to include.
If you are referring to spark plugs, lol, read Richards response!
Unless I am missing something there should only be 1 knock sensor, port side towards the front, starboard side drain plug should be towards the rear, if you have a shower it would most likely be taped in there. 2 manifolds you got, 1 drain at the bottom of the U-pipe adjacent to your water pump and if you have a heater that would need to be drained as well. After that I am not sure what a VDrive would have, probably a drain at the trans cooler, maybe more.
Search for winterizing or similar and you should find pics, been many a thread on it.
Why are you draining now, another hemisphere??
