2007 super air 210 excalibur 330 engine plugs loction
  • jarvis78
    • Jun 2010
    • 9
    • 2007 super air
    How many plugs are there, and where are they located? Anyone have pics?
  • xrichard
    • Aug 2008
    • 669
    • El Dorado Hills
    • 2023 G23
    Please don't take this the wrong way, but if you aren't sure by looking at the motor, you might want to have a mechanic do the work. It's surprisingly easy to mess up plugs if you're not familiar with replacing them.
    In any event, there are 8 and you can find them by following the plug wires.
    Previous boats:
    2015 G23
    2008 SAN 210
    2002 XStar
    1995 Sport Nautique
    • shonuff
      • Sep 2010
      • 157
      • Atlanta, GA
      • '05 SANTE
      Do you mean drain plugs for winterizing?
      2005 SANTE
      • Quinner
        • Apr 2004
        • 2246
        • Unknown
        • Correct Crafts
        Question is too vague, LOL.
        If you are referring to plugs to drain the water there are several in various places, if you have a hot/cold water shower would be an important detail to include.
        If you are referring to spark plugs, lol, read Richards response!
        • jarvis78
          • Jun 2010
          • 9
          • 2007 super air
          Sorry, I meant the plugs to drain the water out of the block. I removed the two knock sensors and the 2 manifold plugs.
          • HS
            • Oct 2007
            • 1333
            • Sammamish, WA
            • 2010 SANTE 210 (Sold)
            The PCM manual for your year on this page:
            http://www.planetnautique.com/vb3/co...Owners-Manuals
            • xrichard
              • Aug 2008
              • 669
              • El Dorado Hills
              • 2023 G23
              LOL....heh...I was obviously thinking spark plugs, but drain plugs makes much more sense!
              Previous boats:
              2015 G23
              2008 SAN 210
              2002 XStar
              1995 Sport Nautique
              • Quinner
                • Apr 2004
                • 2246
                • Unknown
                • Correct Crafts
                Unless I am missing something there should only be 1 knock sensor, port side towards the front, starboard side drain plug should be towards the rear, if you have a shower it would most likely be taped in there. 2 manifolds you got, 1 drain at the bottom of the U-pipe adjacent to your water pump and if you have a heater that would need to be drained as well. After that I am not sure what a VDrive would have, probably a drain at the trans cooler, maybe more.
                Search for winterizing or similar and you should find pics, been many a thread on it.
                Why are you draining now, another hemisphere??
