Fly High Fittings: PVC Cement Needed or Not?
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    FH suggests coating the threads of its fittings with PVC cement when fitting up the sacs in a piggy back system. Is this for water tight fitting or to prevent the fitting from backing out, or what? What is the consensus among you guys that have done set ups? just wondered if the step can be skipped.
  • vanislwake
    • Apr 2010
    • 113
    • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
    I never use PVC cement I have a set of bags that the installer had used it on and those fittings won't come out total pita. They have orings and I've never had leak issues witout using the PVC cement I will never use it on my setups.
    Current '02 sante full '06 updated
    Previously owned:
    07 San 210
    05 Sante
    03 Sante
    01 San 210
    02 Air nautique
    00 Air nautique
    + another 15 non nautiques
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      Put a little silicone grease on threads to ensure the fitting is completely in without having to damage them with overtightening, and they will not leak or come out.
      2005 SV-211
      • johnboyy7
        • Oct 2009
        • 409
        • houston
        i just use teflon tape. works great. no leaks.
        04 SANTE 210
        89 SPORT
        • Chad52
          • May 2004
          • 295
          • Huntsville, AL
          • 2008 Super Air Nautique 210 2003 Super Air Nautique Team 210 2001 Super Air Nautique Team 210 1999 Super Air Nautique 210 1994 Mastercraft Prostar 190 1992 Manta Ray 189 Sport
          I talked with somebody from Fly High and asked this very question. The answer I was told is that if the sack is crammed into some compartment and filled, the fittings could be pressed up against the sidewalls and come under a bind. The cement helps to hold them in in this situation. In my installation, there is no way for them to come under a bind like this, so I just used teflon tape.
          • yager97
            • Apr 2010
            • 33
            • Ontario, Canada
            • 2004 Nautique SV-211 Team Edition
            Don't do it! I have ballast bags that came with them cemented in and now I need them out. Anyone know any tricks?
            • HS
              • Oct 2007
              • 1333
              • Sammamish, WA
              There is a demo on you tube. Heat it up with a hair dryer for about 5 to 10 minutes first
