Originally posted by ffmedic74
View Post
Silicone is bad for vinyl, and I suspect so too are most or all surfectants, but not sure About those.
ctantsNow
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
Originally posted by scott resick View Posti just applied mine today........I give it an "eh" so far. Cleaned the seats nice. A pain to buff off, streaked allot. Had to keep rubbing and rubbing and rubbing. But, if the river stains come off nicely I will use again. We shall see.
Well, that is BTS doing its job. It is binding with the old wax in the pores of the gel coat and lifting it to the surface for removal. With the next coat you will notice that there is less smear and it will be a lot easier to apply. We suggest that 3 coats will get you to ultimate protection. Being that BTS is so easy to apply you can get 3 coats done in a weekend if you are industrious.
Please check out the BTS website for more tips and ideas. A good place to start is: http://www.btsprotectant.com/about/faq/.
Hope this helps,
Rob
That's right HS. No need to wax. You can wax over BTS but there is no need to do so unless you just like to wax. Many use BTS as a wipe down detailer as well. Just spray a little on a microfiber towel and wipe. Keeps a killer shine and protection on the boat with ease.
Rob,
If this is a wax replacement and can be used on gelcoat, seats, tower, speaker cans, etc...what shouldn't it be sprayed on? I plan on ordering some and giving it a whirl.
Thanks,TexasAg01 - Paul
'00 SANTE 210 - Current
'89 Supra Conbrio
'85 Glastron
Thanks,
Originally posted by TxJole View PostChexi I have some sample bottles but will be stuck in Dallas till the weekend of May 4th.Now
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
That makes sense. Well, I'm going down there May 4th and staying down there for about 4 days (friends coming in from out of town to go boarding and such). If you will be there at the same time and don't mind letting me try a sample, we can hook up then.Now
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
