Really? Again? This time seemingly minor, I have a leak on the plate where the gasket and the axcess to the impeller is. Really really minor leak, but it will bug me and with all the problems I have had with my RWP, I wont be able to stand it for fear of it taking down my boat again. I did a little research and my water pump is a part number 1012 from PCM (a sherwood based pump) Sherwood no longer makes this pump and it is being replaced by the 1014. I have a email in to sherwood to ask if this pump aleiviated the problems brought on by the previous 1012 that was riddled with the recalls for a no prime condition that my boat specifically had (03 SANTE). I am on my 3rd pump, with the brand new replacement lasting 2 months and about 20 or so hours. Even with a new impeller, it would not prime. It was brand new in the box last year. PCM replaced that one with a used one, I didnt really care, just as long as it worked, and it seems to have been good until now.
Granted my boat is an oddball with the 02-03 specific waterpump with the v belt. I just figured I would post this up hopefully help others who hopefully will never have to deal with it as bad as I have done to this point. I did find this new pump for a good price ad thought if I can get some confirmation from Sherwood on this new pump being better, I will just buy another one and put this issue to bed once and for all.
In the meantime, I have 2 new impellers and gaskets coming next week. The pump in there now did not have any RTV on the gasket. What do you guys normally do? I was thinking of setting a thin skin of black RTV on it just to seal it a bit better and make sure it wont leak. ANy thoughts?
Just to clarify, 2 of the 3 waterpumps I have had, had the machining for the rubber o-ring which I used with no problems. this one does not have that which is not rare since most websites that cary the impeller kit mention the need for a paper gasket. So the use of the rubber o-ring is out.
I will keep this updated in case anyone needs to search this, it will be here. I will post Sherwoods response as soon as I get it.
