I know there are alot of good threads on this topic but I didn't want to hijack any of them. Anyway, I have a 99 Air with the stock ballast system. What would you do to improve it without tearing out the hardtanks? I want to keep it as a crossover and would like to fill and empty faster. Plus it seems to fill even though the valves are closed. Should I get a better pump, bigger piping, larger hullthrough, etc. ? I'm dumping a lot of money into this thing and can't afford anything elaborate until maybe next winter.
Tags: None
Sorry, your thread got buried quickly under a lot of site activity.
Since the season is starting already, if I were you, I would keep it "as is" until you are ready to upgrade to bags/impeller pumps/etc.
"Plus it seems to fill even though the valves are closed. "
Are you saying that it is filling when the seacok is closed or when the dash air vents are closed? If you shut off the seacok(s), the tanks should not fill up.Rob
2000 SAN
Originally posted by wakemeup3460 View PostI know there are alot of good threads on this topic but I didn't want to hijack any of them. Anyway, I have a 99 Air with the stock ballast system. What would you do to improve it without tearing out the hardtanks? I want to keep it as a crossover and would like to fill and empty faster. Plus it seems to fill even though the valves are closed. Should I get a better pump, bigger piping, larger hullthrough, etc. ? I'm dumping a lot of money into this thing and can't afford anything elaborate until maybe next winter.2002 SANTE
First, are your pumps even working? Are both of them working? My fill worked... my empty did not (before I ripped out the entire system).
You can get a pretty good wake out of that boat with all ballast hidden. I ripped out the hard tanks and put 2x400s in the rear, along with 2x160 lbs of pop bags hidden behind the rear seat where it curves around (160 on each side). I had about 460 in a ballast bag in the belly and the integrated bow sac about half full. You can approximate this with weight on top of your hard tanks, but you need to support it. The flimsy floor the boat comes with is not enough. Search my name to see what I did to do this (as an interim step before I ripped out the hard tanks).
Also, PM nautiquestealth on here. He has my old 99 Air and has had some time to play with weight and its effects on the wake.
All of this said, ripping out the factory system and putting in a johnson impeller system was the best upgrade I did to that boat... and I did a lot of upgrades. It is pricey, but so worth it.Now
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
Originally posted by crobi2 View PostSorry, your thread got buried quickly under a lot of site activity.
Originally posted by Chexi View PostFirst, are your pumps even working? Are both of them working? My fill worked... my empty did not (before I ripped out the entire system).
