I took my boat out for the first time in a while so the batteries were a little low. I just started it and a warning light came on the dash that said low voltage and then all my gauges, 12v outlet, and speakers quit working. The perfect pass and the don't operate over 1000 rpm light remained working. And the bought continued to run fine all day. Does any one now what the problem is I would rather fix it my self then pay a ton at the dealership.
Start with the battery. Put a volt meter on it and see what it reads with the engine not running. My bet is that you have a bad battery.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I know this is an old post, but I'm digging around to find out how to fix my low voltage problem. Did you get yours fixed? how? My 12v outlets are all running at 10-11v and my dash meter says 10-11vols, beeps at me, but may batteries are full and everything else runs fine. I have 12.8 v going inot th ebreaker box under the dash.
