bilge pump on new 200
  • laurie88
    • Mar 2010
    • 75
    • model 206
    bilge pump
    does anybody know if the factory wire the manual side instead of the auto wire to the battery
    my auto bilge pump does not function with the battery switch off, only on manual when the battery is switched on.
    Obviously the pump needs to be live whilst kept 100% in the water
    does the floor lift up close to the pump to get access
    thanks guys
  • skiinxs
    • 374
    • St. Louis
    • 2019 Ski Nautique 6.2 arriving soon
    Originally posted by laurie88 View Post
    bilge pump
    thanks guys
    I believe that the master disconnect disconnects everything, including the pumps. There are two pumps, one close to the pylon base and one under the gas tank.
    Dave
    16 other Ski Nautiques
    3 MasterCrafts
    18 Ski Supreme's
    1 SlickCraft Squirt Boat
    • laurie8888
      • Dec 2011
      • 162
      • dubai
      • nautique 206 and 200
      That does not quite make sense
      If one goes away for extended period of time and leaves the boat in the water and turns of battery isolator off, and boat springs a leak........it sinks!
      The idea of auto bilge pump is to prevent that happening and that is should be automatic and cycle every 3 minutes to detect rising water level
