Jabsco Impeller
  • tgator96
    • Jun 2011
    • 127
    • Gainesville, FL
    • 2012 SANTE 230 ZR 409 2010 SANTE 210 (sold)
    Jabsco Impeller
    Last year we took a vaca with our boat only to have an impeller fail in our ballast pump. We didn't have a spare so it was a bit of an issue. The mechanic at our local AD suggested we change the engine impeller every season after it's sat over the winter just to be safe. What's a reasonable interval for replacing the JABSCO impellers?
    • Feb 2025
    I asked this question a year ago, and the concensus answer was "when it breaks". These tend to last a lot longer, and the result if they fail is not catastrophic. Carry 1 spare. Also, if you reverse the pump for a half a second at the end of each fill and empty cycle to set the fins in the correct direction for their next use, it will help a ton on longevity.
